Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Cool(BEM) doesn't look for space on the right drive!
4 REPLIES 4
753 Views, 4 Replies
Hi Team!
Even though I have my ASMI 2015 Temporary Files as well as Windows TMP/TEMP folders moved from a small system drive C:\ to a large data drive D:\, when it comes to run a large Cool (BEM) analysis (or any Cool(BEM) analysis w/o Mesh Aggregation), the program only looks for space on the system drive C:\ and aborts due to low space there. On drive D:\, I still have almost 1TB of free space!
This is a bug; please inform Development; Thanks
Piotr
4 REPLIES 4
yannick.moret
Hello Piotr,
Please log that through subscription center.
You need to check your temp directory is properly set in registry : HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Moldflow Insight\2015\Environment
If you changed it manually there, ensure you restarted the job manager.
I haven't been able to reproduce your issue, it works well for me, screen output showing disk available for D drive
regards
Yannick
in reply to: yannick.moret
Dear Yannick - as I said, my temporary files are set to D:\ASMI2015 Temporary Files in the Registry.
I did create a support case for it; Thank you
Piotr
yannick.moret
There are 2 places in the registry...one for synergy and one for insight.
Ensure it is the one for insight you setup, and if you edited them manually, a restart of job manager is necessary.
Also, you can check your server properties in job manager that it is taken into account.
Hope this helps.
Bingo!
Both Insight and Synergy's environments are set to 😧 in the registry, but - for a reason I don't understand - the Job Manager has been set to C: (even though a directory doesn't even exist there). I have no idea how it changed, as it was set to D:\ last time I checked (when running a DOE using additional server).
I changed the setting in the Job Manager props and everything is OK now; thank Yannick!
