Converting UDB file of old version to make compatible with moldflow 2012
we have UDB files for many of the material we use regularly with moldflow 2010/2011
But when we run analysis with 2012, moldflow is throwing an error saying, udb file is
not compatible with 2012 version.
How to convert the same to make compatible with 2012?
This morning I asked to tech assistance for the same problem.
If a material has non-conidential status, you can find it in the new database. This was my case.
Otherwise you have to ask to your material supplier for the new data, because the shrinkage data are different for each version.
Another way if you are not interested to shrinkage results, is to edit the material setting the uncorreted residula stress.
