Hi!
I installed AMI2014 this time and i seek for the opinion to switch to the classic UI but i did not found it.
is there no opinion to switch from Ribbon UI to the classic UI?
Best regards
Günter
Solved by caitlin.tschappat. Go to Solution.
In AMSI 2014 there is no longer the option to switch between the ribbons.
The "Classic" ribbon was an older intereface that wasn't being updated while we were transitioning into the new ribbon.
