Need help i use Mouldflow Insight 2014.I mesh already after input injection Locatian want to start analysis.Fill and all sequence. come out analysis failed! i check the analysis log is C I. Please see the attch file the picture
please see:
Job fails with "c" and "i" listed in the Log in new installation of Moldflow Insight
http://knowledge.autodesk.com/article/Job-fails-with-c-and-i-listed-in-the-Log-in-new-installation-o...
Berndt
You might have installed only 'Synergy,' But not installed the 'solver'
1. Install solver and try.
2.If not re-install and try.
3.Check with licence.
4.if solver in other system, try for network connction.
5. If not try restart system and check.
6. If not take help from autodesk support.
