Discussion Groups
Simulation Moldflow Insight
Member
w18855
About Warpage between non-filled and filled resin
367 Views, 2 Replies
11-18-2012 04:23 PM
Hello
My understanding is that glass filled resin may cause more warpage because of the anisotropy shrinkage. Especially more than 30% filled. I wonder if Moldflow simulation really counts on this or just use shrinkage rate.
I don't really see the big difference in warpage between non-filled and filled resin during moldflow simulation.
Please correct me!
Thank you,
Jung
Please use plain text.
Valued Contributor
abakharev
Re: About Warpage between non-filled and filled resin
11-18-2012 07:04 PM in reply to: w18855
Have you switched fiber orientation calculations On?
Warpage calculations for fiber filled materials does not have much use when fiber is switched off
Active Member
ashwinkumarnr
01-03-2013 12:12 AM in reply to: w18855
Hi Jung,
Can you post some images regarding ther same. How is the filling pattern, and what about the material properties for both filled and non filled materials
Ashwin
