Discussion Groups
Simulation Moldflow Insight
New Member
genovese
API macro, disposing synergy
278 Views, 1 Replies
02-15-2013 06:01 AM
I've realized a VBS automation script using your  Moldflow API's and everything works correctly.
My only question is:
Is there any way to dispose correctly the Synergy interface?
To be clear, using your example script is possible to run Synergy, but there is no any method to close it.
http://wikihelp.autodesk.com/Simulation_Moldflow/enu/2013/Help/Insight/5756-Applicat5756/5778-Exampl...
Running:
cscript.exe //Nologo script.vbs
The cscript termates correctly but the Synergy interface remains up.
Can anybody help me?
Simone Genovese
Please use plain text.
Product Support
nordhb
Re: API macro, disposing synergy
04-05-2013 02:22 AM in reply to: genovese
is a while since you posted this question, and maybe you already sorted it out.
Anyway, there is a way. It is a bit harsh and terminates all synergy.exe processes, no prompts.
Example:
SetLocale("en-us")
Set Synergy = CreateObject("synergy.Synergy")
Synergy.SetUnits "METRIC"
MsgBox "Done?"
'** terminates all synergy.exe no prompt
For Each objProcess In GetObject("winmgmts:").InstancesOf("Win32_Process")
     If objProcess.Name = "synergy.exe" Then objProcess.Terminate
Next
Wscript.Quit
Berndt
Berndt Nordh
