Dear all,
recently , i do a CTE analysis by Abaqus. i want abaqus read the material from moldflow filling and packing results by AMSA.
But there is a error shown as below:
Error in job Job-1: in keyword *EXPANSION, file "Job-1.inp", line 22325: The keyword is misplaced. It can be suboption for the following keyword(s)/level(s): material, gasketbehavior Job Job-1: Analysis Input File Processor aborted due to errors. Error in job Job-1: Analysis Input File Processor exited with an error. Job Job-1 aborted due to errors.
it seems that the abaqus cant do the analysis by the moldflow results. who can tell me why? thanks
hi, Hanno . thanks for your reply.
in fact , i dont't ever see who ever do a case like i said.
so , i don't know where can i get help.
do you ever finished this kind of analysis?
if yes, can i send my INP or CAE documents to you ?may be you can give some advise.
need some information on which release of AMI and Abaqus you are using.
Will contact you directly regarding files.
Berndt
Hi, Berndt,
i have sent the serious number by the post message.
the attachment is the document of CTE analysis, which is a failer analysis.
thanks for you help
I had the similar Problem als yours. How did you deal with it? I'm using Moldflow 2012 and Abaqus 6.10.
I got the error:
Error in job test: in keyword *DENSITY, file "test.inp", line 17981: The keyword is misplaced. It can be suboption for the following keyword(s)/level(s): material
I have two parts in assembly. One of them is plastic, which should use the simulation results from Moldflow. The other one is metall part, which was built in Abaqus/CAE. The density in the error belongs to metall part.
can any body tell me how to fix it?
