Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
3D mesh in Moldflow
2 REPLIES 2
kulandaivel_palanisamy
902 Views, 2 Replies
3D mesh in Moldflow
Dear all,
I used to convert my Fusion mesh (done in Hypermesh) in to 3D in moldflow. After converting into 3D mesh, should I needed to use Mesh => Mesh Repair Wizard for automatic correction?
Thanks in Advance.
2 REPLIES 2
It's not absolutely necessary, but it's better.
If the Maximum Aspect Ratio of the Dual mesh is low (around 12), you'll see that the Wizard won't change the 3D meshing.
Signature: "Maybe Moldflow does not work properly, but the real world neither" my son...6 years old 😉
Thank you Pascal.
