Discussion Groups
Simulation Moldflow Insight
kgonzal5
Accepted Solution
3D analysis "Start Analysis" option disabled.
199 Views, 2 Replies
04-04-2013 09:59 AM
Hi.
I have imported a 3D mesh from Hypermesh, have a .nas extention. I used the mesh wizard to correct the mesh and then, even after putting the gates in the corresponding nodes, the "Start analysis" option is not enabled.
Is there any step I've been missing?
I have:
1. Imported mesh
2. Corrected mesh by using mesh correction wizard
3. Rotated the model to have the sprue positioned at Z
4. Click over the node for the injection point location
Please let me know if I'm missing something.
Please use plain text.
Product Support
nordhb
Re: 3D analysis "Start Analysis" option disabled.
04-05-2013 01:55 AM in reply to: kgonzal5
when importing a 3D tetra mesh in nastran format in needs to be refined.
After import, you see in study tasks and then mesh type symbol says "Refine mesh".
Double-click to enter to Generate Mesh and do a "Mesh Now".
When importing a tetra mesh, the refinement is needed to ensure the mesh quality criteria is met for 3D analysis.
When refinement completed, the mesh type symbol says "3D mesh".
After setting injection location, you can now run analysis.
1. Import nastran mesh
2. Refine mesh (Generate Mesh - Mesh Now)
3. Corrected mesh by using mesh correction wizard (if needed)
4. Rotate the model to have the sprue positioned in Z
5. Click the node for the injection location
Hope this solves your issue.
Berndt
Berndt Nordh
kgonzal5
04-05-2013 07:16 AM in reply to: nordhb
Thank you, it did, but the remesh made some tets with a very high aspect ratio and didn't started. I had to remeshe over and over again to have a good mesh, since the wizard couldn't repair the mesh.
Thanks for the info.
