Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
2-domain pvT Tait model
2 REPLIES 2
729 Views, 2 Replies
I am trying to simulate resin flow in Moldflow. For that I need to determine the Rheological behaviour of the resin.
Can someone tell me where I can find the formula that links the 13 coefficients to the plotted graph of density vs temperature at constant pressures? I can't find anything usefull when I search for the 2-domain pvT Tait model.
Thanks in advance.
Greetings, Anton
2 REPLIES 2
madeb
Hello.
Can you tell me if you find answer?... I must use these coefficients too.
nordhb
in reply to: madeb
if you have measured data, raw data or data points, of material you can contact
Autodesk Moldflow Plastics Labs ( http://usa.autodesk.com/adsk/servlet/item?id=13151393&siteID=123112&linkID=13030537 )
at datafittingmoldflow@autodesk.com and get measured data fitted and an udb-file for analysis in return.
Berndt
Berndt Nordh
