hi
when defining a sequential gating and the valve gates are controlled by flow front and trigger nodes and the user is changing f.e. a location of a injection location AND is using "global merge" the nodes are renumbered.
afterwards all the triggernodes have to be defined completely new.
when simulating big parts with lots of injection locations this can be annoying.
or the filling behaves in a unexpected way because the triggernodes have changed. when simulation time is very long this is recognised to late.
solution 1.: lock the trigger node numbering. so the trigger node keep their number, even when all nodes are renumbered
solution 2: highlite the triggernode location by f.e. an clearly visible arrow
solution 3: change the way to define triggernodes or triggerlocations.
at the moment the user has to "remember" the trigger node. then swich to the property of the valve gate or change to the valve gate timing tab and enter the trigger node.
this could be more comfortable. like f.e. after highliting a node and rightclick, a menue could appear and the user could define "define this node for valve gate XY"
