Valve gates in ASMA
Valve gates in ASMA
My sugestion is to create a possibility to simulate valve gates for a sequencial injection in ASMA Ultimate.
2 Comments
raalteh
Status changed to: Accepted
This has been a long standing request, and it's being considered.
emondpw
I created a block for a 3 port valve.  The plantpartconvert command worked. I placed 3 ports, and checked to ensure that 3 ports were showing in the block.  Next I created a new component in the catalog.  I chose 3 ports on the first screen when creating a catalogue object.  I continued thru the catalog entry, then when I chose the block to bring in, a pop up screen title "Select Block Definition" appeared, stating "There is no block has 3 ports in the selected DWG file".  I went back, did a check and the block is in the drawing chosen.  Has anyone ran into this problem? What to do next?
