Option to provide alternate trigger points for sequential valve gates
For example : If we have provided 4 cold gates for single hot drop, then flow front can reach early to any one of the cold gates.
Such case, we have run the one iteration to find out, which gate receives the flow @ first. Then in next iteration, we need to select the earlier flow reaching gate node as a trigger node.
Solution : Instead of that, if given an option like Node no1, node no 2, Node no 3( i.e 1,2,3). It should trigger valve open, which ever comes first.
