Moldlow Communicator on tablet
As Moldflow Communicator can be use to present results to customers, it could be a good idea to have this sofware supported on tablet (any OS).
it would allow to share in an easier way results.
Regards
Cédric
4 Comments
yannick.moret
Note that you can export results as FBX, and show them with Inventor publisher on a tablet.
That can help.
madhukeshwart
I wish same in android phones.... 🙂
zhangchar
You should be able to install it on a Windows Surface Pro. Communicator supports both Windows 8 and Windows 8.1
raalteh
Status changed to: Accepted
Hi All,
The request is fair, and ... at the moment I can tell you that Communicator in its current form is not portable to non-windows platforms because several of the licensed components we use within out product simply are not supported on these operating systems.
Havind said that ... if you currently save a .mfr file to A360.autodesk.com, you can visualize the results in a standard browser. The functionality of this first viewer is very limited, and it will be replaced by a new platform that is in development within Autodesk. So what currently is there is not as fully featured and it will be replaced with something that's even newer. This is why we have not published this actively.
We understand the request though and agree that this is valid.
