Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Ability to open Logs file from job manager
I would like to add the ability to open Logs file of a job that is running without having to open the file itself.  Important as 3d files get larger and larger.  At times I do not want to open the model due to the amount of RAM required if I am already near limit of RAM.  I see this often during cooling analyses.
5 Comments
raalteh
Status changed to: Accepted
Understood
raalteh
Impelemented in Moldflow 2016
bernor_mf
see on-line help for Insight 2016:
View analysis logs without opening the study
lothar.weber
But it does not work in 2017?!
New IDEA?
BR
Lothar
bernor_mf
@lothar.weber
It works when a project is open, and right-click over study and select "View Logs"
2017: View analysis logs without opening the study
The option to select "View Logs" from the new job manager in 2017 is not available.
This should be re-introduced, to be able to "View Logs" from the new job manager, as pretty handy, and no need to open a project to view status of log.
So a "new" idea...
Berndt
