hello
how can I export circuit water and cooling circuit 3D CAD to Moldflow advise
is that there is another software that can export the original circuit without building
I try with extension. igs I spend a lot of time to convert the online channel
Solved by nordhb. Go to Solution.
the geometry for cooling circuits in Adviser are 1D-beam elements, generated from curves/lines.
The workflow is to create the center line/curves in cad system, and export in iges format, and then import to Adviser.
See Help:
Modeling > Cooling system > Import and export >
When importing an *.igs or *.iges file, the process will import each segment of the cooling system as a centre or axis line, and apply default cooling channel dimensions. Baffles and bubblers are converted into cooling channels, and these elements will need to either be defined or added manually after import.
To import
Click Geometry tab > Cooling System panel > Import Channels.
Berndt
I have design a bufflor type cooling channel on Solidworks. But i am totally unable to transport it to moldflow. I tried all the optios as per the help info in moldflow. specially .adv or .udm or how to export an axis even. Any help please?
Fisseha
