I need to interface my MFA 2014 results with ANSYS for structural analysis. Whether its possible ??
Thanks in advance
Solved by nordhb. Go to Solution.
there is a product called Autodesk Moldflow Structural Alliance 2014, AMSA.
AMSA maps mechanical properties calculated by Moldflow to Ansys.
You need Autodesk Simulation Moldflow Adviser Ultimate 2014
(see: http://www.autodesk.com/products/autodesk-simulation-family/compare/moldflow-products )
Compatible software.
ANSYS Classic 12.1 and 14, 32- and 64-bit versions
ANSYS Workbench 12.1 and 14, 32- and 64-bit versions
You can find Autodesk Moldflow Structural Alliance for download at the subscription center.
http://subscription.autodesk.com/
You need a valid account to access.
Note: All ANSYS analysis calculations that use Autodesk Moldflow Structural Alliance 2014 are based on a linear elastic material.
You have more details in the Autodesk Moldflow Structural Alliance, AMSA, installation guide which is available to download with the software.
Hope this helps.
Berndt
please, also have a look at this:
Berndt
