Discussion Groups
Simulation Moldflow Adviser
Active Contributor
dinesh27mec
iNTERFACING MOLDFLOW ADVISER 2014 WITH ANSYS
344 Views, 2 Replies
01-19-2014 10:45 PM
I need to interface my MFA 2014 results with ANSYS for structural analysis. Whether its possible ??
Thanks in advance
Dinesh Kumar D
Please use plain text.
Product Support
nordhb
Re: iNTERFACING MOLDFLOW ADVISER 2014 WITH ANSYS
01-20-2014 02:34 AM in reply to: dinesh27mec
there is a product called Autodesk Moldflow Structural Alliance 2014, AMSA.
AMSA maps mechanical properties calculated by Moldflow to Ansys.
You need Autodesk Simulation Moldflow Adviser Ultimate 2014
(see: http://www.autodesk.com/products/autodesk-simulation-family/compare/moldflow-products )
Compatible software.
ANSYS Classic 12.1 and 14, 32- and 64-bit versions
ANSYS Workbench 12.1 and 14, 32- and 64-bit versions
You can find Autodesk Moldflow Structural Alliance for download at the subscription center.
http://subscription.autodesk.com/
You need a valid account to access.
Note: All ANSYS analysis calculations that use Autodesk Moldflow Structural Alliance 2014 are based on a linear elastic material.
You have more details in the Autodesk Moldflow Structural Alliance, AMSA, installation guide which is available to download with the software.
Hope this helps.
Berndt
Berndt Nordh
Product Support
nordhb
01-20-2014 02:38 AM in reply to: nordhb
please, also have a look at this:
http://forums.autodesk.com/t5/Simulation-Moldflow-Adviser/Autodesk-Moldflow-Structural-Alliance-2014...
Berndt
Berndt Nordh
