After running a gate location analysis, is it possible to show the ideal gate location on the part without applying it?
Solved by nordhb. Go to Solution.
you can view the Flow resistance indicator, but this will not show an exact position for gate location.
Flow resistance indicator is the result plot when using Advanced Gate Locator algorithm.
Best gate location is the result plot when using Gate Region Locator algorithm.
The injection location cone for gate location is added when applying, as you write.
What you can do if you want to view Flow resistance indicator plot,and applied gate location at the same time:
1) when applying the gate location: create a copy of study.
2) open study with Flow resistance indicator result
3) Tile windows
4) Lock views.
Hope this helps.
Berndt
Thanks, I think I'll submit that as an Ehancement Request.
you can post ideas and enhacement requests for Autodesk Simulation Moldflow Adviser
at the Simulation Moldflow IdeaStation.
Berndt
