Moldflow Adviser Forum
Welcome to Autodesk’s Moldflow Adviser Forums. Share your knowledge, ask questions, and explore popular Moldflow Adviser topics.
Problem with mold flow adviser
1 REPLY 1
509 Views, 1 Reply
I can't use my mold flow adviser. When I try to run it, my computer display the window I add to attachments. Could You help me please?
1 REPLY 1
nordhb
from what I see this is the student version.
1) Did you register and get license?
2) Have you set up license service?
Have you used the student support
http://www.autodesk.com/education/support
tab Installation & Activation
Further, this topic is probably better to raise in Installation & Licensing forum,
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
3) If you have done above, check that licpath.lic holds local host ip-address 127.0.0.1, as if using Moldflow and license server on same machine a license failure can occur
if not set as such.
Hope this helps.
Berndt
Berndt Nordh
