I got this report when import:
model stability check was not run for this model
How can i solve?
tks,
Solved by nordhb. Go to Solution.
when importing the geometry, in the Import Wizard Advanced Options dialog, you need to check "Check suitability".
Check suitability :
Determines if the model is suitable for 3D or Dual-Domain analysis.
If not checked, it will not run, and you get the message you mentioned.
Hope this helps.
Berndt
