Moldflow Adviser Forum
Welcome to Autodesk’s Moldflow Adviser Forums. Share your knowledge, ask questions, and explore popular Moldflow Adviser topics.
Packing pressure profile
1 REPLY 1
reynoldesign
881 Views, 1 Reply
I want to prepare or import a packing injection pressure profile. I will use ABS material. What should be my criteria for preparing this profile or Is there anywhere in the net to add this profile ? I have never used ABS material before.
I think mpa should give this profile from database.
Please show me a way or send a sample profile.
1 REPLY 1
nordhb
in reply to: reynoldesign
the concept and procedure of Packing Profiles is well documented in the Help.
In Autodesk Moldflow Adviser - Help:
tab Contents
Running an Analysis > Process settings > Profiles > Packing Profiles
and
Running an Analysis > Process settings > Profiles > Examples of packing/holding profiles
and more on profiles.
To be able to use packing profiles in Autodesk Moldflow Adviser you need
the package Autodesk Moldflow Adviser Manufacturing or Autodesk Moldflow Adviser Advanced.
Hope this helps.
Berndt
Berndt Nordh
