Moldflow Adviser Forum
Welcome to Autodesk’s Moldflow Adviser Forums. Share your knowledge, ask questions, and explore popular Moldflow Adviser topics.
Opposite colours in warpage result?
1 REPLY 1
629 Views, 1 Reply
Hello Autodesk friends,
I am user of Moldflow Adviser 2012 and I would like to ask you for help with following problem:
Result from warpage analysis (dual domain) shows hight deflection colored by red and low deflection by green colour. But in figure down captured from my result there is a heighest gaps betwen original and deformed shape in the area of green, and lowest gaps in the area of red colour.
Please hepl me, how can I understand this result.... Thak you very much!
1 REPLY 1
nordhb
the reason for this is which reference the deflection result is using when displayed.
By default it uses a best fit.
You can set a Anchor Plane as a reference, or pick your own reference points for a best fit.
The deflection magnitude is the same, but you change the reference how to display the deflection.
When result is displayed, you can do this setup on how to display results in tab Tools.
See Help for information, or wikihelp at:
http://wikihelp.autodesk.com/Simulation_Moldflow/enu/2013/Help/4Adviser/1747-Results1747/1880-Warp_a...
Having a cylindrical part, as I see it, you need to set/change the reference to evaluate/analyze the result.
Also, the warp result is shrinkage and deflection.
The max deflection is quite low too: Nominal Max Deflection set to 0.05mm
Meaning:
Green : < 80% of 0.05 mm: < 0.04 mm
Yellow : 80-120% of 0.05 mm : 0.04-0.06 mm
Red : > 120% of 0.05 mm : > 0,06 mm
Berndt
Berndt Nordh
