Moldflow Adviser Forum
Welcome to Autodesk’s Moldflow Adviser Forums. Share your knowledge, ask questions, and explore popular Moldflow Adviser topics.
Moldflow Adviser 2010, how to setup the add-in option in Solidworks 2011
1 REPLY 1
KurtBaker8050
1064 Views, 1 Reply
How do I add Moldflow to the "add-ins" in Solidworks 2011? I went to tools, add-ins..., and there is no selection to start the Moldflow add-in. I have Win7x64 with Moldflow Adviser 2010x64 loaded.
Thanks.
K.B.
Tags (1)
1 REPLY 1
Found out when 2010 Advisor SP1 is installed it loads the Add-in option in Solidworks 2011.
If you updated to 2010 Advisor R2 SP1 it will not install the add-in and will remove the Add-in from the prior version.
So you must use the STL import option, just a few more steps.
