I have installed Mold Flow Adviser 2013, while using any CAD model the mold type option on the ribbon is always greyed out. How can I fix this issue ?
Solved by nordhb. Go to Solution.
this depends on the product installed.
Autodesk Simulation Moldflow Adviser comes in three products:
1) Moldflow Adviser Standard
2) Moldflow Adviser Premium
3) Moldflow Adviser Ultimate
To compare look at:
http://www.autodesk.com/products/autodesk-simulation-family/compare/moldflow-products
If you have installed Moldflow Adviser Standard product, the Mold Type button will always be greyed out,
as Moldflow Adviser Standard is for simulation on cavity only, a single cavity with no runner system "Part Only".
To use Mold Type you need the Moldflow Adviser Premium or Moldflow Adviser Ultimate product
to model single cavity or multi-cavity with runner systems.
Hope this clarifies.
Berndt
