Discussion Groups
Simulation Moldflow Adviser
New Member
TMarques
MPA 8.1 to Win 7
190 Views, 1 Replies
04-23-2012 02:40 AM
Hi
I have a client with MPA 8.1 that is thinking of changing the O.S. from XP Pro to Win 7.
Is that possible? By the way the license is nodelock
Best regards,
Tiago Marques
Please use plain text.
Product Support
nordhb
Re: MPA 8.1 to Win 7
04-24-2012 02:02 AM in reply to: TMarques
MPA8.1 was released about 4,5 years ago, and since the release of AMA2010, about 3 years ago, the licensing system changed.
MPA8.1 is using the previous licensing software Moldflow Product Security, which is a no longer supported licensing system.
If upgrading the OS, this will change the Moldflow license server information, and you will get security failure for MPA8.1. Further, MPA8.1 is not supported on Windows 7 platform. (Now, even if not a supported platform, it might run, but not guaranteed).
If you still want to use MPA8.1, then OS should not be changed.
Otherwise, upgrade to ASMA2013, that will run on Windows 7.
It will also be a floating, network license.
Berndt
Berndt Nordh
