Moldflow Adviser Forum
Welcome to Autodesk’s Moldflow Adviser Forums. Share your knowledge, ask questions, and explore popular Moldflow Adviser topics.
Import Runner System from 3D CAD
3 REPLIES 3
1828 Views, 3 Replies
I tried to search for some information but came up empty.  Basically I was wondering how to import a runner system creaded in 3D CAD to Moldflow Plastics Advisor 2014.  Any help would be appreciated.
Brad
3 REPLIES 3
nordhb
in the cad system: extract center lines of runner system as lines/curves.
Trim lines in the break points, where runners changes direction.
Export the center lines of runner system as iges curves from the cad system.
Before starting import, the geometry setting should be Single cavity or Multi-cavity.
In Autodesk Simulation Moldflow Adviser, go to Geometry.
Click Feed System, down-arrow
Import Runners
File type : *.igs
and select the iges-file.
Then Apply
When importing an *.igs or *.iges file, the process will import each segment of the runner system as a centre (axis) line, and apply default runner system dimensions. You can the change and set appropriate runner properties.
Hope this helps.
Berndt
Berndt Nordh
in reply to: nordhb
Sounds good, now I just need to figure out how to do this in my CAD program. Thanks for the reply.
rustcat
I heard 3D runners can be directly designed in Moldex?  Is that true?
