Discussion Groups
Simulation Moldflow Adviser
Member
Kelson2
Cycle time and Mold Open
457 Views, 2 Replies
04-28-2013 08:33 AM
Upon reviewing the results of a simulations; I realize my project will have some hyrdaulics cores pulls so the mold open time would need to be adjusted.  I adjusted it and reviewed the results again.  I am shocked to see that the pack and cool time had changed.  I thought these were two distinct phases of the cycle.    Why is Moldflow linking them and where is the explanation for this in the help.
What am i missing.
Please use plain text.
gochoats01
Re: Cycle time and Mold Open
08-28-2013 01:30 PM in reply to: Kelson2
Hi Kelson2,
i dont know if im undestanding your question but indeed the packing and cooling phases are different but we have to consider when the cavity fills the packing phase begin and in the same way the plastic part start to freeze even during the packing phase the software must analyze how the part is cooling. You can interpret that the cooling phase begin when the gate is 100% frozen.
I dont know what you mean about the pack and cool time had changed, you mean they increase or decrease?
Hope this helps, if not just ignore me :smileyhappy:
Regards
Member
Kelson2
08-29-2013 07:39 AM in reply to: Kelson2
This is going back some time; so my memory is foggy.
What I noticed was that when I changed the mold open and close time after
the simulation had ran the cooling and pack time changed in the summary.
This did not make sense to me. Mold open and close should be independent
from the cooling and pack times.
Kelson
Kelson Lachance
Engineering Manager
Custom Plastics International Ltd.
887 D'Arcy Street
Cobourg, Ontario K9A 4B4
Tel. 905-372-2281 ext 208
Cell 905-375-5540
e-mail: klachance@customplastics.ca
web: www.customplastics.ca
Notice of Confidentiality:
The information transmitted is intended only for the person or entity to
which it is addressed and may contain confidential and/or privileged
material. Any review, re-transmission, dissemination or other use of, or
taking of any action in reliance upon, this information by persons or
entities other than the intended recipient is prohibited. If you received
this in error, please contact the sender immediately by return electronic
transmission and then immediately delete this transmission, including all
attachments, without copying, distributing or disclosing same.
