Discussion Groups
Simulation Moldflow Adviser
Member
joeprocess
Cleaning up STL files for use with Autodesk Moldflow Advisor 2010
411 Views, 2 Replies
05-08-2009 09:52 AM
Autodesk does not support Magics STL Expert anymore. How do I clean up my files so that the new release works properly?
Please use plain text.
New Member
dkrajci
Re: Cleaning up STL files for use with Autodesk Moldflow Advisor 2010
09-08-2009 08:07 AM in reply to: joeprocess
This seems to be a problem as we were told that Autodesk would not be supporting the product. We have only had stl expert a short time. It seems as even the most simple stl file will not run in newer versions of advisor.
MartinSchultz
09-16-2009 05:15 AM in reply to: joeprocess
When It was announced that Magics would no longer be supported, I took the option of obtaining a perpetual license. I don't know how long I will be able to continue to use it, since it is licensed to a particular piece of hardware, but I do currently use it on every part I analyze.
Magics was actually a repackaging of a third party product, Magics, by Materialise.
http://www.materialise.com/materialise/view/en/2408555-Magics.html
If you Google Moldflow STL Magics you may find something that will work for you.
