Moldflow Adviser Forum
Welcome to Autodesk’s Moldflow Adviser Forums. Share your knowledge, ask questions, and explore popular Moldflow Adviser topics.
Cleaning up STL files for use with Autodesk Moldflow Advisor 2010
2 REPLIES 2
joeprocess
716 Views, 2 Replies
Autodesk does not support Magics STL Expert anymore. How do I clean up my files so that the new release works properly?
2 REPLIES 2
dkrajci
in reply to: joeprocess
This seems to be a problem as we were told that Autodesk would not be supporting the product. We have only had stl expert a short time. It seems as even the most simple stl file will not run in newer versions of advisor.
MartinSchultz
When It was announced that Magics would no longer be supported, I took the option of obtaining a perpetual license. I don't know how long I will be able to continue to use it, since it is licensed to a particular piece of hardware, but I do currently use it on every part I analyze.
Magics was actually a repackaging of a third party product, Magics, by Materialise.
http://www.materialise.com/materialise/view/en/2408555-Magics.html
If you Google Moldflow STL Magics you may find something that will work for you.
