Moldflow Adviser Forum
Welcome to Autodesk’s Moldflow Adviser Forums. Share your knowledge, ask questions, and explore popular Moldflow Adviser topics.
CAE Data exchange
3 REPLIES 3
bernd.rosemann
837 Views, 3 Replies
CAE Data exchange
Hallo,
reading the Autodesk Símulation Moldflow Compare Website http://usa.autodesk.com/adsk/servlet/pc/compare/index?siteID=123112&id=14920771 there is a data exchange feature to autodesk simulation multiphysics from autodesk moldflow advisor ultimate.
Where is a documentation or tutorial available for that feature to transfer simlation results from moldflow to simulation multiphysics?
BR
3 REPLIES 3
nordhb
in reply to: bernd.rosemann
this is available in the in the wikihelp:
http://wikihelp.autodesk.com/Simulation_Mechanical/enu/2013/Help/0031-Autodesk31/0237-Setting_237/02...
There is also an validation document:
Autodesk Moldflow Structural Alliance 2012
Validation Report: Additional Data Mapping to Structural Analysis Packages
which you can access from subscription center:
http://subscription.autodesk.com/
Hope this helps.
Berndt
Berndt Nordh
bernd.rosemann
in reply to: nordhb
wikihelp describes at section Use Moldflow Results - Step 2: "For parts that correspond to the plastic part(s) to be analyzed in Moldflow, set the Element Definition: Material Model to Moldflow. This is an anisotropic material model."
Where is this selection?
Selection Dialog Material Model
Kind regards
Bernd
nordhb
regarding the analysis type in Autodesk Simulation Multiphysics.
The Moldflow element definition is available in Analysis type:
Linear or Non-linear
If you for example select Linear > Static Stress with Linear Material Model
and then enter Element Definition you will see the Material Model: Moldflow
Or if you for example select Nonlinear > MES with Nolinear Material Model
If you have further questions about using Autodesk Simulation Multiphysics,
please, post in forum http://forums.autodesk.com/t5/Autodesk-Simulation-Mechanical/bd-p/396
Berndt
Berndt Nordh
