Moldflow Adviser Forum
Welcome to Autodesk’s Moldflow Adviser Forums. Share your knowledge, ask questions, and explore popular Moldflow Adviser topics.
AutoDesk MoldFlow Adviser - Hung on Splash Screen
1 REPLY 1
791 Views, 1 Reply
Hi, as title subject says
It's a new install on a new machine, pulling a license from a license server, double click the icon, get the initial splash screen and it hangs there.
CTRL-ALT-DEL shows advisor.exe with pc use.
I'm not an expert on Autodesk.  Is there a quick fix for this?
Uninstalled and reinstalled and getting the same thing.
Thanks!
1 REPLY 1
nordhb
the reason is probably that the project folder is for a specific user on network.
Two options here I would say:
1- During installation, point working directory to a local folder such as "C:\My AMA 2012 Projects" reachable by all.
2- Create directory manually and change registry manually
If you are confident to manually change the registry you can do as follows:
Create a local folder via Windows Explorer and name such as C:\My AMA 2012 Projects
Change MPA_USER_HOME in regedit
Start > Run
regedit <enter>
find: HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Moldflow Adviser\2012\Environment
modify MPA_USER_HOME to hold the created local folder such as C:\My AMA 2012 Projects.
Exit regedit
Start Adviser
Note: option 2 means you will not get subdirectories created
You can copy those manually from a previous release folder such as C:\My AMA 2011 Projects.
To change start directory from Adviser user interface:
Top left: M > Options, tab Directories
Hope this helps.
Berndt
Berndt Nordh
