Hi everybody,
I'm using simulation mechanical 2015. I'm trying to do a MES. When i began to run simulation an error occurs and simulation fails. I attached the ds file as a picture. Can someone suggest me something?
Solved by ramses061. Go to Solution.
My guess is that it does not like the special "o" character in the "can ozcan original" folder name. Save the model to a different folder and see what happens.
I changed all the filenames that are suitable with english characters. But still the same error occurs. Isn't there anyone that can suggest me same idea?
I solved the problem by myself. I checked all the parts' configuration and ı found a mistake. I have had chosen a part's element definiton as small displacement. The others were large displacement. I corrected it and the analysis started succesfully.
