Hi everybody,
I'm using simulation mechanical 2015. I'm trying to do a MES. When i began to run simulation an error occurs and simulation fails. I attached the ds file as a picture. Can someone suggest me something?
My guess is that it does not like the special "o" character in the "can ozcan original" folder name. Save the model to a different folder and see what happens.
I changed all the filenames that are suitable with english characters. But still the same error occurs. Isn't there anyone that can suggest me same idea?
I solved the problem by myself. I checked all the parts' configuration and ı found a mistake. I have had chosen a part's element definiton as small displacement. The others were large displacement. I corrected it and the analysis started succesfully.
