Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
turbine analysis
2 REPLIES 2
borikg
689 Views, 2 Replies
turbine analysis
i was wonder to know if Algor simulation is able to analyze turbine analysis, i mean hot air flow via nozzle into turbine blades and rotation of turbine shaft/rotor to evaluate output parameters like mechanical power, velocity etc, under loads.
2 REPLIES 2
Joey.X
in reply to: borikg
Try modelling in fluid flow - Multiple rotating frame of reference(MRF), refer to online help in special modeling with MRF.
Note it has no direct mechanical power and under loads output, user needs evaluate them by rotating speed input and velocity and pressure output.
Jianhui Xie, Ph.D
Principal Engineer
MFG-Digital Simulation
jkraybill
in reply to: borikg
borikg, we should talk sometime.  Steam turbine component simulation is what I do and you're only other user I've found so far with similar interest.
Jake K.
