Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
fluid flow+ structural modeling - help
5 REPLIES 5
jkmalagi
562 Views, 5 Replies
Guru's,
I am trying to model a fluid flow system where the outlet flow (Q out) is controlled by the position of a spring-loaded 'float', which moves within a sleeve/outer cover. The outer cover has an inlet port & couple of outlet ports. The inlet port delivers pre-determined quantity of flow (Q in) at given inlet pressures.
Since the location of float is determined by inlet water pressure & spring rating, I am not sure as to how do I model the actual fluid. My ultimate aim is to size inlet & outlet ports for a range of flow rates & determine suitable spring rates for the float within given operating inlet water pressure ranges.
Please see attached image for details.
I appreciate any guidance that you provide.
Regards
Jay
5 REPLIES 5
hupn
in reply to: jkmalagi
Unfortunately, Autodesk simulation currently does not support the case of changed fluid flow domain. I do not realize a good way for your case.
hupn
sunj.autodesk
Unfortunately, currently fluid solid coupling is not supported.
You may try some brutal force approach, first assume the float is fixed, and perform a fluid analysis. Then based on the pressure and spring force acted on the left and right side of the float, move the float a bit to left or right to balance it. Repeat this step and iteratively, you should archive a final state that is close enough to the real solution.
Joey.X
in reply to: sunj.autodesk
sunj's proposal should handle your simple FSI problem although it needs manual iterations. An extra note is using fluid reaction force instead of pressure after fluid flow analysis,  since (a) reaction force is the overall force (pressure and shear stress in tangential direction) while pressure is the component in surface normal direction only; (b) overall reaction on the piston force could be acquired by pick all piston surfaces and get sum.
Jianhui Xie, Ph.D
Principal Engineer
MFG-Digital Simulation
ryan.arnaudin
Jay,
If you have access to Autodesk Simulation CFD (formerly CFdesign), this is something we do fairly often that could be accomplished with the motion module.  Our support folks could walk you through the process of getting this set up if you need a hand.
Ryan
jkmalagi
in reply to: ryan.arnaudin
Thank you all for your prompt responses. I will try the iterative process suggested by Sunj (we have some base line test data to begin with) & close this query as solved as of now.
Ryan - unfortunately we do not have Autodesk CFD module as of now. Thanks for the offer to walk me thru the module though :).
Regards
Jay
