Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
error wrong beam element or beam orientation
1 REPLY 1
flyboy2160
1002 Views, 1 Reply
good evening analysts,
can anybody tell me if this error message says which beam element (each beam is in its own part) is bad?  thanks.
flyboy2160
fem2esh - Make esh file from fem file
Version 23.01.00.0136-W64/X6405-FEB-2009
Copyright (c) 2009, ALGOR, Inc. All rights reserved.
  Version of
fem2esh.exe          : 23.01000136
  Version of dcx1-win-x64.dll     : 23.01000136
  Version of
femapi-win-x64.dll   : 23.01000136
  Version of
agsdb_ar-win-x64.dll : 23.00000132
  Version of
tsx2tsy.exe          : 23.01000136
  Input Model     : C:\Users\flyboy2160\Documents\ALGOR 7-3-2011sq boom - all parts with
error\fus tubes 4 algor.ds_data\2\ds
  Input File      : C:\Users\flyboy2160\Documents\ALGOR 7-3-2011sq boom - all parts with
error\fus tubes 4 algor.fem
  Output File     : C:\Users\flyboy2160\Documents\ALGOR 7-3-2011sq boom - all parts with error\fus
tubes 4 algor.ds_data\2\ds.mod\group.esh
  Log File        : C:\Users\flyboy2160\Documents\ALGOR 7-3-2011sq boom - all parts with
error\fus tubes 4 algor.ds_data\2\ds.mod\group.ldx
  Design scenario : 2
  Analysis type   : Linear Stress
  Start time      : 2011/07/03-19:39:57
  --- Get 435 active
element parts in range [1, 737] from fem file
  --- 47 enabled
L&C groups are defined
  --- Get 1315 points
defined in range [1, 1781] from fem file
  Calling the Surface
Topology Generator (tsx2tsy)...
  tsx2tsy: re-made
part surface contact/bonding data (duration=1 sec.)
  --- No mid-side node
required
  Set up FEM points
and B.C. by connected elements...
  In working on FEM
file or outputtingESH file
  Terminal Error: FEM2ESH#19,
item#2
    Wrong beam element
or illegal orientation
Tags (1)
1 REPLY 1
PipePakPat
in reply to: flyboy2160
The error message states, "Terminal Error: FEM2ESH#19,
item#2", which suggests part number 19 experiences an error on the second item.  It this item is a line from a beam element part, then I would suggest to display the number 2 axis direction on the beam elements in the FEA Editor to ensure these are not collinear (or close to it).
Pat Tessaro, P.E.
Premium Support Specialist – Simulation
Autodesk, Inc.
6425 Living Place
Suite 100
Pittsburgh, PA 15206
