Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
element excavation and installation
1 REPLY 1
420 Views, 1 Reply
I'd like to use ASIM to model geotechnical buildings/tunnels. To this end excavation (removal of continuum elements) and installation of (beam, shell) elements at different time steps are important. Is this possible with ASIM?
Matthias
1 REPLY 1
PipePakPat
One cannot add or remove elements from an Autodesk Simulation Mechanical or Multiphysics (Algor) analysis once the analysis has been initiated.  So the model would have to be created and analyzed with the material already removed.  The available material models are Curve with cut-off, Drucker-Prager and Duncan-Chang.
Pat Tessaro, P.E.
Premium Support Specialist – Simulation
6425 Living Place
Suite 100
Pittsburgh, PA 15206
