Simulation Mechanical and Multiphysics
divide the lines
131 Views, 5 Replies
04-26-2012 06:56 AM
Spoiler
There are some rule, proportion or recommendation for divide the lines (how many divisions) when I work beam elements?
Please use plain text.
Employee
Re: divide the lines
04-26-2012 07:07 AM in reply to: jjohnson
The main thing to keep in mind is that the results are given at the nodes. So you want enough divisions so that there is a node close to where maximum result will occur.
Beam elements are the most accurate element type. (Okay, truss elements are also accurate.)  For example, a cantilever beam (fixed on one end, nodal force on the other end) can give accurate results with just one element: the maximum displacement is at the free end, and the maximum stress is at the fixed end. The results will match the hand calculations.  (I know this is true for linear stress, but I do not know for certain if MES gives the same accuracy.) Of course, with only one element, the displaced shape will look a little bit odd. So in a case where the maximum stress is expected to occur "somewhere" between the joints or supports, you will want to have enough divisions to capture a reasonable result.
I have not tested the following for a long time, but I think that gravity load is approximated by putting half of the element weight at each end of the element. So if gravity were a significant load, then more elements would be recommended to get a more accurate representation.
Sincerely,
John Holtz, P.E.
Senior User Experience Designer, Simulation
Autodesk, Inc.
Current version of Mechanical & Multiphysics: 2013 SP1 (2013.01.00.0012 28-Jun-2012)
Employee
04-26-2012 07:10 AM in reply to: jjohnson
Usually, shorter beams are better according to the general rule on mesh size.
May I know why you ask this? Is your model sensitive to beam length?
If this response answers your concern, please mark it as "solved".
Employee
04-26-2012 07:16 AM in reply to: INACTIVE_AstroJohn
To clarify one thing, which might relate to what John mentioned here.
In ASIM2013, we fixed a bug about beam reaction force calculation in MES when gravity is applied. Right now, the reaction force should be right, no matter how many divisions the whole beam structure is cut into.
04-26-2012 07:34 AM in reply to: jjohnson
I am working an cabin for aerial ropeway.  I am model them with beam elements.  dimensions  width 2000 x depht 1400 x height 2300 mm.  add picture
Employee
04-26-2012 08:51 AM in reply to: jjohnson
I guess:
20 divisions for long beams, 5 for middle ones, and 2 for short ones, roughly.
