I wanted to ask if you know of a way to increase the number of boundary conditions icons that appear on a certain surface. I've created the constrains I needed, and managed to enlarge their icons/change their color, but the sofware shows only 2 boundary icons on them, how can I change it?
Thanks!
ok, found the solution which is to create the mesh. then the software applies the boundary symbold to each of the elements. thanks.
another questions that came up - somehow the autodesk student version isn't able to export pictures. it gives the screen where you pick the desired options but it won't save the picture. does anybody knows what is the reason for that? I can use printscreen but the quality is poor.
Thanks again.
