Hi all
Under "Plasticity" results, should the "equivalent stress" and "equivalent strain" roughly follow the material stress/strain curve?
I am using:
MES with Nonlinear Materials
Von-Mises curve with Isotropic Hardening
ASTM A514 steel (Yield ~ 690 MPa, Ultimate ~ 760 MPa).
Large Displacement
Updated Lagrangian
(Additional output at corner nodes)
As an example, the UTS of the marerial curve is ~758 MPa with 0.18 strain. But the analysis results show a plasticity "equivalent stress" of 764 MPa with 8.7% "equivalent strain" (clearly nowhere close to the material curve data). As "equivalent strain" is a scalar value, I add the elastic strain of 0.3% and get 9% strain. Shouldn't the analysis results follow the material curve?
If I use Total Lagrangian they appear to follow the material curve. I realise UL needs "true stress/true strain", but as a comparitor, the results should still follow the material stress strain curve should they not?
James
