Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Warning during Mesh
4 REPLIES 4
1162 Views, 4 Replies
Warning during Mesh
I got the following during "Mesh":
*** Warning *** Distorted pyramid found, 1 have been split to tets.
   --- Part(1): 25206 type 8 elements, done.
Pls, need explaination, Thanks...
4 REPLIES 4
xli
In quality check of the mesh, it found that pyramid is not good (none positive volume). pyramid's quad is warped  In most such cases so program will split the pyramid to two tet elements to avoid negative Jacobian problem. And that warning is given.
-xli
Thanks..
michwmichw
in reply to: xli
Can this warning dialogue box be disabled?  I cannot find a setting to turn off in the application options.  Frequently, I'll start a simulation before heading home and this dialogue box will prevent the analysis from running overnight.
Mike
AstroJohnPE
in reply to: michwmichw
Hi michwmichw,
The option "Show decoder warnings and continue analysis" located on the Analysis tab under the Application Options should do what you are looking for. If not, please copy the complete text from the log file and paste it into a reply. That way, we can check what is occurring.
