Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Ver 2012 Response Spectrum Stress Results - plate elements
2 REPLIES 2
JohnD.Sherow2645
623 Views, 2 Replies
With Ver 2012 SP1, I do not get stress results for plate or brick elements.  Model consists of plates, bricks, and beams.  I do get stress results for beam elements.
I did get plate stresses with Ver 2011.  I have not gone back to that version as I am hoping that I just need check a box or something. FEM file is 68 mb with modal and response spectrum scenarios, so I have not attached it.
Any help appreciated with limited info I have provided so far.
Wondering if it is a bug.
..........John Sherow
2 REPLIES 2
It seems to be a bug from the new Ribbon style UI. You can disable it by unchecking the "Ribbon Style" box from "Tools"->"Application Options"->"General Information". Hope it solves your problem.
Using the old menu system worked.
Thank you............jds
