I want to create a spring that will break at one of it's ends (or whose constaint with another part discontues) after the spring experiences a certain amount of stress. Is this possible to do using autodesk inventor/simulator? Is there any way to vary the stiffness of the spring? Or use ilogic to end a constraint once the spring experiences a certain stress?
Any help would be much appreciated
If you can use Autodesk Simulation Mechanical, you can try use 'General Contact Element' in nonlinear types.
-Shoubing
Thank you for your input. This information seems pretty useful. I will play around with it more and hopefully I can get the results I am looking for
