Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Tube Chassis Mesh Failure
1 REPLY 1
adai8636
349 Views, 1 Reply
Can anyone advise me on a meshing scheme which will work well with a model that has a high ratio of surface area to volume? I am attempting to find the modes of a chassis of welded tubes. For simplicities sake I have excluded modeling the "welds" but the chassis has been designed in frame generator and then shrinkwraped into a single solid part as a union of all the notched and mitered tubes.
I keep having failures as the tubes have wall thicknesses as small as 0.035 inches but lengths of 12 or more inches.
1 REPLY 1
madg1
in reply to: adai8636
you can use plate elements for meshing
madg1
ASIMM 2012
