When I try to draw geometry, it is difficult to tell what is going on. See attached clip.
Is this right, or is there a setting somewhere that I can change.
http://screencast.com/t/tephvzzlFV
Solved by S.LI. Go to Solution.
There is a OpenGL hardware acceleration option in option->Graphics->Hardware.
Sometimes, to disable this option is helpful in Win7.
Please have a try and let use know your result.
I'm having the sme issue, but the 'OpneGL' check box is gray-out and I can't check it off !
Any idea how to make this option available ?
One of previous post explained this.
1.) you must be the administrator user
2.) could not be remote access mode.
