Discussion Groups
Simulation Mechanical and Multiphysics
Active Member
jiaming0503
Transient analysis -joule heat error?
150 Views, 2 Replies
07-30-2013 01:46 AM
I found that parallel circuit to calculate the joule heat, the temperature of the two branch
Not the same,is this a bug?
Please use plain text.
Valued Mentor
AstroJohnPE
Re: Transient analysis -joule heat error?
07-30-2013 06:04 AM in reply to: jiaming0503
I have studied your information very carefully and determined that the answer is no. :smileywink:
My guess is that you need a much finer mesh and ignore any "hot spots" that occur in the results.
John Holtz, PE
Mechanical Engineer
Pittsburgh, PA
16 years experience with Simulation Mechanical
Active Member
jiaming0503
08-06-2013 01:08 AM in reply to: AstroJohnPE
thanks for your help.
