Simulation Mechanical and Multiphysics
Active Member
Tracker2012
Track meshing
232 Views, 4 Replies
07-12-2012 02:24 PM
I am trying to optimize a sprocket drive but need help simulating the rubber belts holding the drive section together.
Any ideas?
Have access to Several autodesk products. I was able to get a short simulation in Inventor but i need a more accurate one.
I have attached a pdf file showing the basic idea.
Please use plain text.
Active Member
Tracker2012
Re: Track meshing
07-13-2012 08:26 AM in reply to: Tracker2012
i know have a full loop assembly with a drive sprocket and two wheels. The fist run it ran but the belts start to bunch up. So i put a spring between the two wheels and it shows some movement put seems to bind up and stop moving. If any one thanks they can help i can send them the files.
Distinguished Contributor
madg1
Re: Track meshing
07-13-2012 08:43 AM in reply to: Tracker2012
i guess you are in wrong forum....
madg1
ASIMM 2012
Active Member
Tracker2012
Re: Track meshing
07-13-2012 08:52 AM in reply to: madg1
I am wondering if i could or should try this in Autodesk algor Simulation?
madg1
Re: Track meshing
07-13-2012 10:19 AM in reply to: Tracker2012
then  rubber belts  and motion goes non linear....which needs some expert advice...:smileytongue:
madg1
ASIMM 2012
