I am using, Autodesk Simulation Mechanical 2014. and i got a work on thermal analysis.
This is the first time am trying thermal analysis. to understand radiation and conviction i tried with a simple model as shown below
Temp Applied 250Deg C
Ambient Temp 20Deg C
Gap is .2inch between parts.
Can i find the temperature induced in Part 2, due to the applied temperature on part one?
or should i go for Simulation CFD for such analysis?
result i get is
Please clarify me
Hello...
I believe that you have to use THE BODY TO BODY radiation to calculate the radiation from a object to other.Are you going to have a flow between the plates? if not you can draw the air between them.
http://engineeringexploration.autodesk.com/content/module-6-radiation-heat-transfer
check the video
