Discussion Groups
Simulation Mechanical and Multiphysics
Active Member
nivenl
Thermal: How do I find the node number ?
394 Views, 4 Replies
10-22-2013 03:24 PM
After meshing the part, I would like to find out the node's number so that I can specify the orientation for the orthotropic material. Is there anyway to find out what the node numbers are before running the analysis?
Thanks.
Please use plain text.
Product Support
andrew.sartorelli
Re: Thermal: How do I find the node number ?
10-23-2013 05:47 AM in reply to: nivenl
Hi Nivenl!
To determine the node number after meshing you will need to go to the Selection tab on the ribbon and set the selection type to Vertices. Now when you click on a node in the mesh assembly you can simply right click and select Inquire. The inquire dialog will bring up information about Vertex number and coordinate location.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Andrew Sartorelli
Active Member
nivenl
10-23-2013 07:59 AM in reply to: andrew.sartorelli
I actually did try that, but I was not sure if vertice number and node number are the same.
Thanks a lot.
Valued Mentor
AstroJohnPE
10-23-2013 05:47 PM in reply to: nivenl
The vertice numbers in the FEA Editor ARE NOT the node numbers. If they were the same number, we would have called them nodes in the FEA Editor.
To get the node numbers that are required as input for the orientation of orthotropic brick elements, you need to
  1. complete the model
  2. do a "Check Model" (Analysis > Analysis > Check Model)
  3. Once in the Results environment, you can select the node(s), right-click, and "Inquire Results".
  4. Go back to the FEA Editor and enter the node numbers.
  5. Proceed with the analysis.
John Holtz, PE
Mechanical Engineer
Pittsburgh, PA
16 years experience with Simulation Mechanical
Product Support
andrew.sartorelli
10-24-2013 05:27 AM in reply to: AstroJohnPE
John is correct here, I apologize for any confusion my inaccurate response may have caused.
Andrew Sartorelli
